Safety functions and limits
WD-15EFirmware: WD-15E mount build; AHC 1.1.0 interface reference
In this chapter
6.1 Safety-function overview​
Open Settings > Safety & Limits on AHC. Read and record existing values before changing them. The reference interface contains Altitude, EC/HA, Meridian and AEB controls.
AHC safety and limits overview
FunctionPurposeImportant dependency
Altitude limitsRestrict calculated pointing below/above configured altitude boundaries.Correct time, location and pointing coordinates.
Meridian limitsGovern allowable GEM travel and flip behavior around the meridian.Correct mode, pointing state and software coordination.
EC HA LimitPreventive control: constrain encoder-based RA travel, including when sky coordinates are incorrect.Valid encoder data, correct reference, enabled limits and suitable physical boundaries.
AEBPassive/reactive protection: respond after abnormal motor loading is detected and help mitigate its consequences.Enabled state, valid baseline/threshold and firmware-supported behavior; payload, inertia and slew speed affect the outcome.
Power-loss behaviorThe motor provides holding torque only while powered; there is no mechanical RA brake.Support the loaded assembly and keep people clear before disconnecting power.
WARNING · Protective functions are not a clearance guarantee
Inspect the complete mechanical arrangement and travel before moving. AEB responds to abnormal loading after it occurs; EC HA constrains RA travel when its reference is valid. Neither replaces physical clearance checks. WD-15E has no mechanical holding brake when power is removed.
Check safety settings at first use and after firmware updates, Home-reference changes, site/mode changes or alterations to the telescope, camera, counterweights and cables.
WARNING · Restart the mount after changing safety settings
Every change to a safety setting requires a WD-15E mount restart before the new value takes effect. This includes altitude and Meridian limits, EC HA boundaries or enabled state, and AEB settings or a newly saved baseline. Saving or reading back a value on AHC does not mean the active protection has changed. Stop the observation, save the setting, restart the mount and reconnect AHC. Read the setting back and verify the mount's Home/reference state, observing data and applicable coordinate-limit initialization before relying on the protection or resuming normal movement.
WARNING · Coordinate limits need start-up initialization
Forcing Tracking ON before the mount's location and time have been updated does not activate coordinate-based Meridian, Horizon or Overhead / Zenith protection. First verify the site, date and time, then complete a supervised initial GoTo or a verified alignment/plate-solving Sync to establish the pointing state. Merely solving an image, saving limit values or seeing Tracking ON is insufficient. Follow 5.6 Start-up and coordinate-limit initialization and check physical clearance throughout the initial movement.
6.2 Motion and altitude limits​
Horizon is the lowest allowed calculated target altitude. Overhead, shown as Zenith in the AHC altitude page, is the upper altitude limit. These concern sky pointing, not a measurement of physical tripod clearance.
  1. Verify observing location, time and pointing state.
  2. Open Settings > Safety & Limits > Altitude.
  3. Read the current Horizon and Zenith settings. Choose values suitable for the site, observing plan and mount behavior.
  4. Save/apply using the displayed control, then restart the mount to activate the new limits.
  5. Reconnect AHC, reopen the page and read the settings back.
  6. Confirm that ordinary targets inside the intended region remain available without testing a dangerous motion.
AHC altitude-limit settings
NOTE · Zenith and flip behavior
A restrictive upper-altitude limit can affect a near-zenith GoTo or flip. Older OnStep-based instructions describe a 90° setting as disabling the overhead check; do not use that as a universal WD-15E recommendation. Coordinate the chosen setting with the actual firmware and physical clearance.
Do not lower Horizon simply to overcome an implausible target altitude. First check the observing data and target coordinates.
6.3 Meridian limits​
In GEM mode, the meridian is the north–south line through the sky. A target's hour angle (HA) is negative before it crosses the meridian and positive afterward. A meridian flip moves the telescope from one side of the pier/tripod to the other so tracking can continue. The East and West settings describe where each pier-side arrangement may operate around that crossing; they are not motor-direction buttons. The meridian limits depend on correct location, time and pointing coordinates. They are separate from the encoder-based EC HA Limit.
East and West boundaries​
Mount settingEffect on real movement in GEM mode
Meridian East (E)Sets the earliest position east of the meridian at which the telescope may use the pier-east arrangement (the arrangement normally used after a flip). At HA less than −E, the mount stops RA travel farther into that boundary in this arrangement; a GoTo may instead choose the pier-west arrangement if that route is allowed. A positive E can permit an earlier flip before transit.
Meridian West (W)Sets how far west of the meridian the telescope may continue in the pier-west arrangement (the arrangement normally used before a flip). At HA greater than +W, the mount attempts its automatic flip if the conditions below are met; otherwise it stops further travel toward that boundary. A positive W allows tracking beyond transit while the imaging application finishes an exposure and requests a flip.
When E and W leave an overlap, both pier-side arrangements can reach targets between HA −E and HA +W, subject to other limits and physical clearance. A GoTo or flip request inside this interval can select the other arrangement; pier-side preference and the requested command affect the result. The mount does not flip merely because the target crosses HA 0°. Moving E or W changes real allowed RA travel, so check the OTA, camera, counterweight, tripod/pier and cables throughout both routes.
Factory defaults and flip window​
The current WD-15E mount firmware's initial values, used when its nonvolatile limit settings have not been initialized, are:
SettingFirmware initial valueApproximate time from meridian transit
Meridian East0°0 minutes before transit
Meridian West+5°20 minutes after transit
Automatic meridian flipEnabledAttempts a flip at the West boundary when tracking and a flip can be executed
Sidereal HA changes by approximately 1° in 4 minutes. With these initial East/West values, the nominal two-arrangement window runs from the meridian to about 20 minutes after transit. A mount that has previously been configured can have different stored values, including a stored automatic-flip state; firmware initial values do not overwrite its saved settings. Verify the installed mount's actual settings before scheduling unattended imaging. In the current AHC implementation, the Meridian page can display locally stored field values rather than reading both limits back from the mount, so an untouched AHC screen alone does not prove the mount's effective values.
CAUTION · Leave Meridian East at its factory setting
Do not change Meridian East for routine use. Keep it at the firmware's 0° factory value. Changing East alters when the other pier-side arrangement becomes available and can cause an unexpectedly early or refused flip. AHC saves the East and West fields together: before saving a West adjustment, make sure its East field shows 0° unless WarpAstron has specified another value for your mount. If the mount may already have a different stored East value, confirm its configuration with WarpAstron support before saving.
Imaging-software timing​
Set the imaging application's flip window inside the mount's verified window, leaving time for any active exposure to finish, for its flip request to reach the mount and for the setup to remain clear. In N.I.N.A., Minutes after Meridian is the earliest requested flip time and Max. Minutes after Meridian is the latest end of that exposure-dependent window. For example, with a verified West value of +5° (about 20 minutes), a N.I.N.A. window of 5–10 minutes after transit leaves a nominal 10-minute margin before the mount's West boundary. It is an example, not a universal safe setting: first verify clearance, the actual pier side, exposure length, sequence timing, driver behavior and EC HA boundaries. See 4.8 N.I.N.A. Meridian flips and the N.I.N.A. flip documentation.
N.I.N.A. can wait for an exposure already in progress to finish and, when it ends within the configured window, request the flip before starting another exposure. This avoids interrupting that frame only while the mount still has room to track. N.I.N.A. does not move the mount's West boundary or guarantee that a delayed, failed or disconnected application will finish the frame. If tracking reaches the mount's West limit during an exposure, the mount-level response below takes precedence; the frame and guiding may be lost. Use reliable pier-side reporting in the ASCOM driver and supervise the first flip with the actual exposure duration. Avoid competing flip requests from multiple applications.
What happens at the West limit​
If N.I.N.A. or another application requests a valid flip before West is reached, the mount follows that request. If no flip request arrives and the mount reaches West while still in the pier-west arrangement, the WD-15E firmware automatically requests a flip to the pier-east arrangement when automatic flip is enabled, the mount is tracking and the GoTo/flip request can be accepted. The mount does not wait for the imaging application's exposure or guiding to finish. If automatic flip is disabled, tracking is not active or the automatic flip is refused, the mount stops further RA travel toward the West boundary and reports a meridian-limit condition. Other protections can intervene earlier. Do not rely on automatic flip as a substitute for correctly scheduled software flips or confirmed physical clearance.
WARNING · Changing a meridian window
Do not widen the window without checking both pier-side configurations, accessory clearance and cable travel. A permitted software position may still be physically unsafe. A wrong time/location or incorrect plate-solving Sync can also make a coordinate-based meridian boundary correspond to the wrong physical position. Keep EC HA Limit correctly configured as an independent preventive RA boundary.
  1. Stop the current observation and record existing settings.
  2. Open Settings > Safety & Limits > Meridian.
  3. Confirm the actual mount values and the units shown by each interface. AHC displays degrees; N.I.N.A.'s flip timing uses minutes. 1° ≈ 4 minutes near the meridian.
  4. Leave Meridian East at 0° for normal use. If a different Meridian West limit is needed, check the full physical route before changing it. Coordinate the imaging application's earliest/latest flip timing, including exposure duration and a margin before West.
  5. Check that EC HA Limit leaves room for the intended normal flip, while still stopping before unsafe mechanical travel.
  6. Save/apply the new values, restart the mount and reconnect AHC. Confirm the mount's stored values through a supported readback method, re-establish the observing/pointing state as needed, then supervise the first actual flip.
EC HA Limit can stop RA travel before a software flip is completed if its boundary is reached first. Conversely, increasing a software meridian limit does not increase safe physical travel.
6.4 EC HA Limit​
EC HA Limit is encoder-based mechanical RA travel protection. The AHC interface calls it EC/HA; older WarpAstron material also uses EC Guard. It measures RA rotation relative to the stored encoder Home reference. This mechanical angle is different from the target's celestial hour angle or the sky coordinates reported after a pointing Sync.
NOTE · Preventive control
EC HA Limit provides a preventive travel constraint. With valid encoder/Home reference data, enabled limits and correctly placed boundaries, it can prevent unsafe RA travel caused by incorrect synchronized sky coordinates. It checks encoder-referenced RA travel rather than depending only on the celestial pointing solution. This provides an additional barrier when a GoTo or Park command is based on incorrect coordinates.
An incorrect plate-solving Sync can change the mount's pointing coordinates so that software Meridian, Horizon and Overhead limits no longer correspond to the actual physical position. EC HA Limit's encoder-referenced RA boundary provides an additional preventive constraint in that situation. Verify time and location and the solved position before Sync; do not deliberately use an incorrect Sync to test protection.
It limits the consequences of a coordinate error; it does not correct that error. Keep time, site and pointing synchronized, and leave a stopping margin inside known physical clearance. Its RA boundary does not establish DEC, accessory or cable clearance.
For the supplied firmware reference, this is a GEM-mode protection. Do not assume the same function is available in AltAz mode. A valid physical Home/encoder reference and usable encoder readings are essential.
Read the boundary illustrations​
The RA encoder Home reference is 0°. The initial reference-firmware boundaries are −95° and +95° of mechanical RA rotation from that position. They are firmware starting values, not guaranteed clearance for every telescope, DEC orientation, accessory or cable route. A previously configured mount can retain different settings. Check both limits with the complete loaded assembly, and leave room for deceleration. If the RA Home reference changes, the same numbers correspond to different physical positions and must be verified again.
WD-20E illustration of the encoder-based RA boundary principle. The initial ±95° values are not a WD-15E clearance test; verify the safe range with your complete setup.
Shared EC-series RA positions: minus 95 degree example, Home at zero and plus 95 degree example
Watch the coordinate-error animation​
An incorrect plate-solving Sync can make the reported sky position differ from the actual telescope position. A coordinate-based Meridian stop can then act at the wrong physical place. With a valid encoder Home reference and EC HA Limit enabled, RA rotation is also checked against its mechanical boundary. At the reference −95° boundary, for example, the mount commands a stop even if the sky-coordinate solution is wrong. The mount can continue moving while it decelerates, and this RA check does not protect DEC, accessories or cables.
WD-20E illustration of a coordinate error and a separate mechanical RA boundary. The sequence is conceptual and does not represent WD-15E stopping distance.
Shared EC-series illustration comparing a correct coordinate stop, a coordinate error and an encoder-based EC HA stop
Shared EC-series animation illustrating how a mechanical EC HA boundary remains independent of an incorrect sky-coordinate solution. Motion and stopping distance are illustrative.
CAUTION · Never test a limit by causing contact
Do not deliberately drive the telescope into a pier or tripod. EC HA does not correct wrong coordinates or a bad Home reference, and it cannot guarantee that a heavy or fast-moving load stops before contact.
Configure the boundaries​
The reference firmware initializes EC HA Limit enabled with −95° / +95° mechanical RA boundaries, but a configured mount can retain other values. The current AHC page may show locally stored fields rather than reading the mount's active boundaries. Treat the illustrations and any untouched AHC fields as examples until the actual configuration is confirmed; saving from AHC writes both boundary fields.
  1. Confirm the installed WD-15E firmware, GEM mode and valid Home/reference state.
  2. Inspect the telescope, camera, focuser, counterweight and cable clearance on both sides of the travel.
  3. Open Settings > Safety & Limits > EC/HA. Confirm the enabled state and actual stored boundaries using a supported readback or WarpAstron support if the AHC display cannot establish them.
  4. Record the previous values. Change only values whose units and reference directions you understand; do not save simply to match the illustration.
  5. Keep each boundary inside a known clear region, leaving a margin for deceleration and cable movement.
  6. Coordinate the boundaries with meridian limits, so the intended normal flip is not unexpectedly blocked.
  7. Save/apply the settings, restart the mount and reconnect AHC. Confirm the mount's stored values and enabled state through a supported method before relying on the boundary.
  8. Verify normal movement within the known safe region at low speed, while supervising the equipment. Do not create a collision to test protection.
WARNING · Stopping distance
The mount can travel beyond a trigger boundary while decelerating. Leave clearance beyond the configured angle, especially at higher slew rates. A boundary positioned exactly at contact is too late.
Reference and encoder checks​
An absolute encoder does not by itself make an incorrectly defined Home reference safe. Do not clear or redefine that reference casually. Follow the encoder Home calibration guidance and recheck the boundaries after a reference change. If Home was interrupted, encoder status is abnormal, or the reported position disagrees with the actual mount, stop and resolve the discrepancy before relying on EC HA Limit.
The local firmware reference requires current, valid encoder information for this check. Loss of usable encoder information must be treated as a reason to investigate; an enabled toggle alone is not proof that effective protection is present.
When an EC HA boundary is reached​
During normal GEM operation, reaching an EC HA boundary commands an RA stop, aborts an active RA slew and turns Tracking off. Some subsequent motion commands may be refused. Confirm that movement has actually stopped, then stop the controlling sequence and inspect the axis position, warning, boundary setting and cable clearance.
If the mount permits a short manual movement away from the boundary and that direction is clearly safe, use low speed and verify the warning clears. A Home return should be used only when its full route is clear. If the position/reference is uncertain or recovery is refused, stop and contact support rather than widening the boundary or repeatedly restarting.
6.5 AEB​
AEB is the mount's automatic emergency-braking protection. It uses motor-load information and a configured baseline/trigger setting to detect abnormal loading. The reference implementation can stop motion and briefly reverse the affected axis to relieve the load. Keep the surroundings clear for both the original and possible recovery direction.
CAUTION · Passive response and heavy-load limitations
AEB is passive/reactive protection: it responds only after abnormal motor loading is detected. Contact, obstruction or cable tension may already have occurred before it triggers. Its stop and possible relief movement can mitigate the consequences only to a limited extent; it cannot guarantee that equipment damage or personal injury will be avoided.
Heavy or bulky equipment, added counterweights and large lever arms can increase the moving assembly's inertia. Higher slew speeds increase its kinetic energy. These factors can make stopping or load relief less effective; movement and contact forces may continue during detection and deceleration. Do not rely on AEB to make a heavy setup or a marginal-clearance route safe. Use conservative loading and slew speed, check the entire route and cables, configure preventive limits, and remain ready to press STOP.
EC HA Limit sets preventive RA travel boundaries; AEB reacts to abnormal loading. Use both within their supported operating conditions, together with physical clearance and supervision.
An incorrect plate-solving Sync can corrupt the pointing coordinates and undermine software Meridian or altitude limits. AEB responds to motor loading rather than relying only on those sky coordinates, so an enabled, correctly tuned system can offer a reactive fallback if abnormal loading occurs. It does not detect or correct a bad Sync, and contact may already have occurred before it responds. Its mitigation remains limited, particularly with heavy equipment; verify time, location and synchronization and use preventive travel limits before movement.
Illustrated AEB response​
For an obstruction, the possible sequence is contact → increased motor load → AEB stop → possible brief reversal. This is a conceptual sequence, not a guaranteed response time or reversal distance. AEB must be enabled and tuned for the installed load. Contact may already have caused damage before detection. Wait for motion to end before inspecting the equipment; never create contact to test AEB.
WD-20E illustration of the AEB response principle. Contact may already have occurred; WD-15E stopping and reversal distance vary with load and speed.
Shared EC-series AEB example showing contact, commanded stop and possible brief reverse movement
Shared EC-series animation illustrating abnormal-load detection, a commanded stop and possible brief reversal. Timing and reversal distance are illustrative.
Check AEB and its settings​
AEB is disabled at the factory by default. Enable it if you intend to use the feature, and read the enabled state back. A previously used mount may retain changed settings, so check the actual state at first use and after updates.
Use the supported AEB Auto Tune workflow for the load you will operate, including telescope, camera, other accessories and counterweights. Reassess the baseline after changing that assembly. Enable the required functions and complete all prerequisites before starting Auto Tune; it must not be started merely to suppress an unexplained warning.
  1. Open Settings > Safety & Limits > AEB.
  2. Read its enabled state, recorded event count, baseline and threshold/ratio fields.
  3. Record current values before making changes.
  4. Use the supported calibration workflow to establish a valid baseline when required. Do not enter a guessed value or copy a value from another mount.
  5. Save/apply the intended settings, restart the mount and reconnect AHC. Read the values back before relying on AEB or starting Auto Tune.
A baseline that is too low can cause unwanted activation. An excessively high trigger can reduce sensitivity. AEB values are not equivalent to the published payload torque and are not a direct torque calibration.
AEB Auto Tune​
AHC firmware 1.1.0 or later is required for AEB Auto Tune from AHC. The WD-15E mount firmware must also support the guided workflow; meeting the AHC minimum alone is not sufficient. The presence of an AEB setting on older firmware does not establish support for guided Auto Tune. Use the workflow offered by the installed, supported combination; do not substitute a legacy PC-tool sequence for it.
WARNING · Reduced protection during recording
Auto Tune records motor loading while normal current-based AEB protective action is reduced/suppressed. Check the entire chosen travel in advance, remain beside the mount, and be ready to press STOP. Disconnect independent PC, ST4 and other command sources before starting. Do not use a deliberate collision as a calibration test.
The guided sequence is Home → select East or West → prepare → record while returning Home → save the baseline → restart. The reference workflow uses RA movement for a shared baseline with DEC at Home. Follow the actual AHC prompts for the selected direction and any Restore Speed recovery; do not reproduce the sequence manually.
WD-20E illustration of the Auto Tune sequence. Follow the installed WD-15E and AHC prompts; this is not a manual motion sequence.
Shared EC-series AEB Auto Tune workflow from Home through preparation, recording, baseline save and mount restart
Prerequisites
  • AHC firmware 1.1.0 or later, compatible WD-15E mount firmware and a connected AHC.
  • GEM mode, valid encoder position and enabled EC/HA and AEB functions as required by the workflow. If any of those safety settings were changed, restart the mount and verify their active states before Auto Tune.
  • A physically correct, completed Home state, tracking off, no active slew or guiding, and the required unparked state.
  • Clear travel toward the selected east/west preparation position and back to Home, including all attached equipment and cables.
  • No independent controller issuing commands; stable power and access to STOP.
Procedure
  1. Complete the prerequisite checks, then open Settings > Safety & Limits > AEB > Auto Tune.
  2. Select East or West according to the side whose full route is clear. Read and acknowledge the displayed conditions.
  3. Press Start Auto Tune. Watch the preparation movement and stopped-state checks.
  4. Continue supervising while the mount records loading and returns to Home. Do not manually change speed, mode, protection settings or position during the workflow.
  5. If motion is unexpected or clearance becomes doubtful, press STOP / Stop / Cancel and follow the recovery screen.
  6. When the result is presented, confirm the mount has returned to Home and stopped. Review the outcome; a lack of actual calibration movement is not a valid successful result.
  7. Choose Save Baseline to accept the result, or Discard to retain the previous baseline. Wait for the displayed save/cleanup result.
  8. If the workflow requests Restore Speed, complete it and verify recovery before leaving the workflow.
  9. If you saved a new baseline, restart the mount to load it. Reconnect, check AEB/EC HA status and observing data, and verify the normal operating speed before resuming.
The reference workflow derives a shared baseline from RA movement; it does not perform an independent DEC calibration. The supported guided implementation manages preparation speed and recording. Do not attempt to reproduce its motion with a stopwatch or raw commands from a terminal.
Cancellation or interrupted tuning​
Cancel and wait for a confirmed stop. Keep any recovery screen visible and follow its instructions. If the AHC restarts or cleanup cannot complete, reconnect to the same mount and complete the offered restoration before normal operation.
If a save acknowledgement was interrupted, do not assume the old or new baseline is active. Restart as instructed and read the stored value back. For unresolved recovery or an invalid result, preserve the previous records and contact support.
After an AEB event​
Stop the sequence and wait until motion and any protective reversal have ended. Inspect for contact, cable snagging, overload, stiff movement, loose attachments or a changed equipment configuration. Read event information and the current baseline/trigger settings.
Remove the cause before resuming. If activation repeats without an obvious obstruction, check supply stability and calibration with support; do not repeatedly raise the threshold to suppress an unexplained event.
6.6 Other protective functions​
Other protections depend on the delivered hardware and firmware. They can include motor fault handling, axis-travel restrictions and electrical protective circuitry. Read the actual status and release notes for the installed version.
WD-15E has electrical monitoring for its one saddle PD output, Port A / CH1, visible on the AHC Power page when compatible telemetry is available. Port B is data-only. Voltage/current readings do not stop a telescope collision or prove an accessory receives the voltage it requires. See 7.6 Power monitoring and 4.9 Saddle power and data.
Electrical protection is not permission to use the wrong voltage, polarity or connector. A motor fault is not necessarily a limit event. Keep the reported error available for diagnosis.
6.7 Stop movement and handle abnormal operation​
  1. Press AHC STOP when movement or clearance is unexpected. Use the software's documented abort control if that is the available route.
  2. Confirm physically that motion has stopped; a lost connection alone is not confirmation.
  3. Keep clear of the equipment and inspect the reported state and surroundings.
  4. For smoke, electrical smell or continued uncontrolled movement, isolate power safely while accounting for the unsupported load: WD-15E has no mechanical holding brake. Do not reach into a moving mechanism.
  5. End other command sources so they cannot restart the mount.
WARNING · Power isolation and load holding
Removing power may be necessary in an emergency. The motor supplies holding torque only while powered, so a loaded axis may move when supply is removed. Keep people out of the possible load path and support the equipment safely once movement has stopped.
6.8 Recover after a protection event​
Use this sequence for an event whose cause has been identified:
  1. Stop imaging, guiding and other command sources. Record the warning and settings before clearing anything.
  2. Inspect the complete setup, cables and attachments. Correct the obstruction or configuration problem.
  3. Determine whether the event came from EC HA Limit, AEB, altitude/meridian settings, a motor fault or another source.
  4. Follow the matching recovery procedure above, using only a clear, allowed route. Do not treat a reboot as proof that the cause is resolved.
  5. Confirm physical position, Home/reference state, observing data, safety settings, tracking and Park state as applicable.
  6. Make a short supervised test at low speed, then resume normal operation only if the result is consistent.
For repeated or unexplained events, collect the diagnostic information in 8.8.
